clearnetedm wrote:
---However I noticed the TW is different when the bars are hooked vs not. So which TW would be the correct? In my case one of the weights is over the rated hitch while the other isn't.---
The correct TW is approximately equal to the TV's GVW with trailer attached and no WD applied minus the GVW for TV only. I assume this difference was 420kg (926#).
With WD applied some of the load on the TV is transferred to the TT's axles. The trailer axle load increased by 2460-2390 = 70kg (154#). That's approximately equal to 926-794 = 132# (60kg), with the difference being attributed to scale accuracy.
The TW (926# in this case) should not exceed the TV's receiver TW rating.
Ron
