waynec1957 wrote:
My thinking is (and I could be wrong) if a TT is designed with a certain unloaded weight distribution (certain TW) to make it stable during towing, that should be the numbers I use when it’s fully loaded (should it not?). For instance a TT designed with a dry weight of 7,000 lbs and a dry tongue weight of 700 lbs, when loaded to (for instance) 8,500 should have a TW of 850 lbs.
I suspect that, as you mentioned earlier, lower trailer tongue weights are solely to make the trailer "half-ton towable". I do not think that lower tongue weights can in any way make the trailer more stable in towing.
You have a much more positive attitude about travel trailer manufacturers than I do.
Although 10% might be sufficient for a low side trailer, I would never go below 12% and prefer 13-15% for a loaded travel trailer, no matter what the dry weight percentages are.
