Crespro's avatar
Crespro
Tongue Weight Rating
Hello,
We are buying a trailer for our daughter and son-in-law. They now have a Ford Expedition with 8,900# tow rating. 80% of that is 7,120#, but they should stay below 7,000# loaded (5,500 to 6,000# UVW) because there is an 895# tongue weight rating. The Expy has a GVWR of 7,100, so the full 895# is available with fuel, oil, pax and baggage.
I bought a Sherline so we can test to load between 12% and 13% for tongue weight. We also have a new Equalizer 10,000/1,000 hitch.
Question: Is the 895# rating when loaded with the Eq. hitch or unloaded? With the Eq. hitch in place, the load on the Expy is about 80% and 20% is shifted to the trailer dual axles.
Thanks from a trailer "newbie,"
Crespro
  • sch911 wrote:
    How much does the Expedition weigh loaded for travel?
    Subtract that from the Expedition's GVWR and you'll know if it has the capacity.
    Yes, you need to get it weighed...
    We will weigh it. For now, UVW of 5,700, passengers of 350, fuel and oil of 180, baggage of 150, tongue weight 80% of 895=720 for a total of 7,100#.
    While I am in a 33K motorhome and not a TT, it seems to me that you would want the TV to be close to GVWR. Heavy vehicles ride better and are more stable in the wind.
  • Ron Gratz wrote:
    Crespro wrote:
    Question: Is the 895# rating when loaded with the Eq. hitch or unloaded?---
    For the 2006 Expedition:
    The 895# maximum tongue weight applies when you are using a weight distribution hitch.
    If not using a WDH, the maximum tongue weight is limited to 600#.
    Ron
    Ain't it amazing how the WDH rated tongue weight is almost exactly 10% of towing capacity. Seems its that way on most all Fords.
    The 895# maximum tongue weight rating for the receiver applies when you are using a weight distribution hitch.
    If not using a WDH, the maximum tongue weight rating is limited to 600#.
    Ron
  • How much does the Expedition weigh loaded for travel?
