LarryJM wrote:
Well as far as cargo behind the axle the "experts" at e-trailer seem to have a different opinion ....
tongue wt. added to receiver rating
Larry, the "expert" failed to explain that allowing for weight of cargo behind rear axle only is necessary if you are going to use the WDH to compensate for the effect of that weight on the TV. Others, who also might be considered to be experts, disagree with this approach.
The majority of TV and WDH manufacturers agree that, if a WDH is used, it should be adjusted to restore the front of the TV to its unhitched height or somewhere above the unhitched height.
I've never seen anyone specify that the unhitched height should be measured with no cargo behind the rear axle, and you then should add that cargo to the TV and connect the trailer.
Since the behind-the-axle cargo already is in the TV when the unhitched height (or load) is measured, the WDH
does not compensate for the weight of that cargo.
Even if one did go to the trouble of unloading the behind-the-axle cargo prior to measuring the reference height or load and then reloading that cargo, the effect of that cargo on the TV only would not be the same as an equal amount of tongue weight.
Again I was careful to keep my comments about the receiver ratings as they are listed as tongue wt. I can't do the analysis you can, but I can appreciate that cargo wt. behind the axle is part of the wt. that the WDH leverages and transfers since the pivot point is basically the rear axle so any wt. behind that might have to be handled by the WDH system. Thus I would count the WDH wt. as cargo basically added behind the rear axle.
IMO, the WDH should be in the receiver and the bars (along with
all of the TV's cargo) should be on/in the TV when the unhitched heights or loads are measured. If you choose not to do that, then
a portion of any weight which is added to the TV after the reference measurements are made can be considered to be redistributed by the WDH.
However, we should consider that receiver tongue weight ratings probably are based on the assumption that the WDH will be adjusted to give "equal squat". Since that approach seldom is used these days, the actual loading of a receiver by a WDH probably is significantly less than the receiver's design assumptions.
While you don't consider the bike rack like the WDH wt., but again neither do the TW ratings of the receiver spell out that the wt. of the WDH is tongue wt in a weight carrying mode (i.e. the draw bar and even the spring bars if not engaged), but are a free wt. when the WDH is engages.---
Sorry, you lost me there.
---Also, do you advocate subtracting the parts of the WDH like the spring bar brackets that generally stay on the tongue from the actual tongue wt. somehow?.---
I would consider the weight of the spring bar brackets to be part of the weight of a typical WDH which probably is allowed for when the receiver's TW rating is established.
I guess then you stance/opinion is that the wt. of the HA is a freebe on any considerations as far as weight goes which I don't think is a universally help view from my reading.
IMO, the weight of the HA (or any other WDH) should be treated as part of the TV's GVW. If you are going to use the WDH to achieve "equal squat", I would recommend that you consider the weight of the HA, minus 100#, to be added to the trailer's tongue weight.
BTW e-trailer also considers wt. behind the rear axle as going against "tongue wt" CLICKY even in a WDH scenario and I think it's reasonable to consider the WDH wt. as basically cargo or wt. behind the rear axle.
Is this information different from that presented in your first CLICKY?
Ron
