myredracer wrote:
I think the harder thing to picture is what happens when the spring bars are hooked in place. In a way, it would *seem* like when you tighten up the chains, the tongue coupler gets pulled down onto the ball and therefore that the ball would get a higher vertical downward force which in turn would be transferred down to the ground.
But as you tighten up the chains, more of the weight of the rear of the truck (at the ball) is being suspended by the chains. This thus relieves some weight off the ball and rear axle of the truck. At the same time, due to leverage action, the chains pull down vertically on the A-frame transferring weight to the TT axles. Also at the same time, with the spring bars being pulled upward, there is a leverage action that tilts the front of the truck downwards thus transferring weight to the steer axle.
I'll offer a slightly different description of the process and include some example numbers to help put things in perspective.
When the lift chains are tensioned, they pull up on the WD bars and pull down on the trailer's A-frame.
The downward force on the A-frame is applied approximately 30" behind the ball.
Let's assume the distance from the ball to the midpoint between TT axles is 240".
Let's also assume the tension in each lift chain is 880#.
Since the point of application of lift-chain force is much closer to the ball than to the axles, a larger portion of the force will be carried on the ball.
In this case, the downward force on the ball is increased by 2*880*(240-30)/240 = 1540#.
The downward force on the TT's axles is increased by 2*880*30/240 = 220#.
Assuming a tongue weight of 1000#, the combined downward force on the hitch head is 1000+1540 = 2540#.
However, each WD bar is being pulled upward with a force of 880# for a total upward force of 1760# applied to the hitch head.
The resulting vertical force on the hitch head is 2540-1760 = 780#.
This is numerically equal to the TW minus the 220# which was transferred to the TT's axles.
The net effect on the hitch head is the same as exerting an upward force of 220#.
There also is a pitch-axis torque applied to the hitch head. For this example, the torque is 2*880#*30" = 52,800 lb-inch.
Assuming the upward force of 220# is applied 65" behind the TV's rear axle, the upward force generates an additional torque of 220#*65" = 14,300 lb-inch when using the TV's rear axle as a fulcrum.
Assuming a wheelbase of 130", the TV's front tires will react against the torque with an upward force of (52,800+14,300)/130 = 516#.
As a check, If we calculate the 220# added to the TT's axles multiplied by distance from TT's axles to TV's rear axle and then divide by TV's wheelbase, we get 220*(240+65)/130 = 516#.
The upward force of 880# applied to each WD bar has caused 220# to be transferred to the TT's axles and 516# to be transferred to the TV's front axle.
This means 220+516 = 736# has been removed from the rear axle.
If I am visualizing this correctly, there is therefore no net increase in weight of the coupler acting downward upon the ball. Structurally, the TV can handle the lower rating receiver rating without WDH engaged (say 500 lbs). Then when the WDH is engaged (with 1500 lb rating), there is no net additional downward force onto the ball itself and the receiver and TV does not actually "see" the additional 1000 lbs the tongue may be. Have I got this right at all, or am I out to lunch?
Application of WD does cause a significant increase in vertical force between coupler and ball.
However, the upward force from the WD bars (acting upward under the ball) causes the net vertical load on the hitch head to be reduced by an amount equal to the load which is transferred to the TT's axles.
The net load on the hitch head will be less than the tongue weight.
500# of tongue weight, without WD, will produce 500# of vertical load on the hitch head.
In my example above, the assumed 1000# of tongue weight, with WD applied, produced 780# of load on the hitch head.
When you go to a scale, the empirical data proves this to be true. It would be interesting to test this with some type of strain gauge or load cell.
The scales prove, within their accuracy, the load on the hitch head is reduced by an amount equal to the load which is transferred to the TT's axles.
Further to this discussion, I'm wondering what happens to weight transfer and weights/forces between coupler & ball when you use over or under-sized spring bars? Is there any difference in weight that the ball sees when the WDH is engaged? If you have say 1000 lbs of tongue weight, and only 800 lb bars, if you tightened the heck out of the bars to get enough weight onto the steer axle (if you even could), what happens? Same if you go the other way with over-sized bars and had say 1200 lb bars? Or does it even affect anything other than having a bouncier or harsher ride? Perhaps with too under-sized bars, there could be higher momentary up/down force between ball and coupler as you drive down the road? Could this possibly over-stress the receiver?
When using WD bars, if the rear of a TV goes through depression relative to the front tires and TT tires, the load on the WD bars will increase. This will cause increased loading of the coupler, ball, and hitch head.
Higher-rated (stiffer) bars will cause more load increase -- lower-rated bars will cause less load increase.
Normal driving down the road should not cause overstressing of a receiver.
VESC-5 specifies that the test torque (moment) for a 1000# tongue weight should be 114,200 lb-inch. This is more than double the WD-bar generated torque (which produced more than 100% of front axle load restoration) in my example above.
Ron
