Both are the weight on the ball.
The ball isn't going to snap off the hitch at the higher weight. The issue is if there are 4 bolts (2 front and 2 back):
- Without the WDH, the rear 2 bolts must support the entire weight and the front 2 bolts act as a pivot point (though there should never be pivoting) because the ball is further from the pviot point compared to the rear bolts, the rear bolts must support more than the actual ball weight.
- The WDH, creates an opposing moment arm, so the front bolts carry some of the ball weight significantly reducing the force on the rear bolts and allowing a much higher ball weight.
