jpmogle1's avatar
jpmogle1
Tongue/Hitch Weight Conundrum
Hi Everyone,
I am quite novice on the towing capacity and was alerted by a friend that the vehicle I purchased may not support the trailer we are looking to purchase this weekend. We have a 2021 Subaru Ascent with a factory installed receiver. The max towing capacity is 5000 lbs. with a tongue weight of 500 lbs. We are making a deal on a 2022 Forest River Ozark 1680BSKX with a dry weight of 4050 lbs, a GVWR of 4905 lbs. and a hitch weight of 505 lbs. per the manufacturers site: https://forestriverinc.com/rvs/toy-haulers/ozark/1680BSK/5802
The concern is if we take into consideration the 10-15% rule of the trailer, we are between 405 lbs and 607 lbs for tongue weight. However if we take the GVWR into consideration we are at 490 lbs to 735lbs., which is way too much.
The trailer dealer states we are within 'range' and should just distribute weight properly. Subaru has warned that going over 500 lbs is dangerous and also could void the vehicle warranty. Any assistance on how to determine which is correct would be much appreciated!
  • No matter what, you will be maxed out, even if you somehow keep it "just under" the limits using whatever math you use...
    My 13 F150 has a "tow rating" of #11,000... ha, ha... I'm 'maxed out' for my own preferences with the #7000 loaded TT I have now and I'm able to tow it with ease and enjoy the ride.
    If you are taking a poll.. I would say go a little bit lighter than #4900 GVWR TT for your vehicle..
    Good luck! Mitch
  • Nv_Guy's avatar
    Nv_Guy
    Explorer III
    My opinion is you will be overloaded, as RV manufacturers tend to underestimate their products weight, much the same as users underestimate how much stuff they load in their RVs.
    With that being said, unless you want to weigh the trailer and tongue weight then carefully load everything to make sure you are "within range" I would find a different unit, because the real issue here is the razor thin margin of error, as you can end up with a combination that is not only dangerous, but a real chore to drive.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    yes you may be in trouble. the quoted hitch weight is with an empty trailer, no propane in the tank(s), no battery(s) installed no water in the tanks. So I suspect your "guess" of 500-700 lbs is more realistic and will likely be over 600 once loaded.
    As an example our trailer had an advertised tongue with of 750lbs, which I verified was correct when empty. Once we put on 2 batteries, filled the propane, loaded the trailer with our stuff and fill the fresh tank, tongue weight is 1450lbs! If fresh tank is empty and grey black near full it's up over 1500lbs.
    Vehicle mfg "assume" 10% hitch weight when doing their calculations on capacity for towing. Trailer mfg design to near 15% tongue weight. See the disconnect!
    And more than likely that "5,000lb" towing capacity assumes the tow vehicle has a driver, full tank of gas, no passenger and no luggage. Passenger weight and luggage weight subtracts from towing capacity.
    I don't know which transmission the subaru has, but if it has a CVT, that's another potential reliability issue if overloaded. CVT's are great for many applications, reliable, low loss, etc. but they currently haven't been able to be designed to handle heavy load applications on a continual basis. If it has a CVT that may be the limiting factor on towing.
    Similar issue on vehicles with DCT transmission especially w/o a torque converter in front of the transmission. to easy to burn up the clutches when towing. (Don't believe subaru uses and DCT's)
