timskiwannacamp wrote:
Looking at Laredo 298RE 7120# LW. Have Silverado 1500 5.3 W/ trailering pkg, HD cooling pkg, integrated brake controller, 3.42 rear end. I feel we are too close to maxing out capacity or already over. Would appreciate thoughts and suggestions. Thanks in advance.
Not enough info for a good response or if just looking for confirmation
of what you want to hear...you will get that in spades...but note that
there is only one person responsible for the setup (gets the ticket)
and that is the driver (which may not be the OP)
Gather the specifications (limits and ratings) for 'your' TV and
either learn how that system works, and/or post them here for advice/opinions
GVWR of both TV and trailer
GAWR, both front and rear
GCWR
actually go out and weigh your TV both empty and fully loaded. Axle
by axle. That is the only way to know where you are in reference to
your TV's specifications
Then do the simple math figuring out the 'true' max trailer weight rating...MTWR
