1jeep wrote:
Cummins, hows does that box mount into the bed, did you have to drill holes in the truck bed?
I used a 1/2" self drilling "Wafer" head screw in the upper right and left corners of the toolbox into the upper bed at the top inside rail.
The toolbox is designed for a 94-2002 RAM, that is what I had it in first. When I bought my 11 RAM dually I figured I would give it a try. The box fit tight between the "D" rings on the sided of the bed. If you buy the box made for the 10 and newer RAM's you will have a narrower toolbox with room to access the two D rings. I like the way this fits. If I were to buy a new one I would get this same model.
