AnEv942
Mar 30, 2015Nomad
Problem with the Torklifts app. guides they do not list the arms and the mounts separately, part numbers are for both. Generally its the mount thats unique. Your fronts should be same (arms) rear- one variable is hitch. but
I will say this when I switched factory receiver (01 F250) to super hitch, I also ordered new rear mounts. The arms were the same as my old ones (and same as used on fronts) only the mounts attaching to the hitch was different.
http://www.torklift.com/documents/appguides/application_guide.pdf
but a call or note to Torklift should verify.
