Dome wrote:
mine don't engage till there is a load on. then I pump up the air bags till the stable loads just touch the spring. for me thats about 30# pr. side. I guess the load would determine how much air one would use.
Same here. Works like a charm. The bags carry 90% of the weight and the Stableloads resist leaning in corners etc. I went ahead and cut off the extra 2" of stud which makes them a breeze to remove when not hauling the TC. I use the bags to raise the rear end enough to wiggle the Stableloads out and then air down. The overloads don't seem to touch with 10 psi in the bags so no reason to re-install the OEM pads. and I get a softer ride.
