raztec's avatar
raztec
Explorer II
Oct 12, 2013
Tork Lift Stableloads?
I've got a Dodge Ram 3500 SRW 4x4 and carry about 3000lb, wet camper + trailer.
I've got air bags, but they make the truck sway.
Looking to give it stability and someone on the Cummins Forum mentioned the Torklift Stableloads. I've got upper and lower overload springs, but don't want to drill any holes so I'm going to use the uppers only.
Anyone have any experience with the upper stablelift overloads?
How about anti-sway bars?
Which would you do first to decrease the sway and give the truck some stability especially going off road?
Thx a bunch
R
  • Dome wrote:
    I was set up the same way, I put the fork lift stable loads in and it helped because it contacted the springs sooner. I left the original spacer in so it contacts the spring sooner than just the stable loads alone, you will have drill out the stock spacers so you can use them both. If you don't have a trace bar on the rear end you may want to consider getting one. thats what really cut down the sway for me.
    Did you use the upper stableloads or lower?
    Is a trace bar same as an anti-sway bar?
    Thx
    R
  • I was set up the same way, I put the tork lift stable loads in and it helped because it contacted the springs sooner. I left the original spacer in so it contacts the spring sooner than just the stable loads alone, you will have drill out the stock spacers so you can use them both. A sway bar on the rear end is what really cut down the sway for me. But I'm glad I put the two product on the truck. Now I set the air pressure in the bags just enough to make contact with the springs and I good to go.
