- BradWExplorer III have no doubt the oem 3" hitches are well designed and plenty strong enough when used as intended. When I was crawling around under new trucks investigating the ford oem hitches, I could tell they used high strength steel just from the sound they make when getting pinged with a screwdriver. Sounded like heat treated and/or high carbon content. Also, the 3" hitches were made of thicker steel than the 2-1/2" hitches. I measured the sideplate thickness and seems like one was .170" and the other was .210".....or something like that.
bradw - SidecarFlipExplorer III
BradW wrote:
Bedlam wrote:
Torklift's ratings are based on using the Ford OEM receiver. It may be a limitation of the receiver with that much leverage........
That was my concern. Ford doesn't publish any ratings for those OEM receiver hitches when used with an extension. I have no doubt the Cannon extension tube will handle what its rated for and I have no doubt TL performed some testing before they put these on the market.
Having said that, I removed the OEM hitch from our 2018 F350 and installed the 30k lb TL hitch. The TL hitch is massive as compared to the OEM hitch and weighs much more.
I'll be towing slightly more than 6,500 lbs on a 4' extension, so I would exceed the new Cannon rating anyway. I will be a lot more comfortable with the TL hitch and dual extension.
bradw
I can tell you who makes 90% the receiver hitches for Ford and has for a while. Midway products, P&A Division in Findlay, Ohio I delivered countless loads of High Strength AKDQ 10X material there over the years. Company I drove for was their number 1 supplier of flat rolled high strength steel.
The balance is made by Draw-Tite in Indiana and we supplied them with high strength as well.
I think Midway did all the roll forming for everyone. They had 3 Yoder mills in Findlay.
Might be different now, been retired for 10 years. - ticki2Explorer
Kayteg1 wrote:
I wouldn't dare make the stories , you already have that market cornered .ticki2 wrote:
A 1/4" x2" steel bar could hold that hanging. 7000 lb truck . It would make a very weak trailer hitch .
Well, most of the hitches are squares made of 1/4 x 2 walls.
You can make the stories all you want, but from what I have seen how my 3" receiver and stinger works, I think if you could hire Hulk for the test, he could lift Superduty horizontally holding it by the stinger. - Kayteg1Explorer IIShow me 1 mounted on 3" stinger?
- jimh406Explorer III
Kayteg1 wrote:
OK, I let them go now, but if they copy my rear-mounted crane, I see them in court. :C
That’s nice of you. You do know that there already a number of hitch mounted cranes and have been for years. You already have plenty of people to see in court. :D - Kayteg1Explorer II
deltabravo wrote:
Kayteg1 wrote:
Shall I sue for copyrights?
Sure, and watch the attorney laugh at you.
OK, I let them go now, but if they copy my rear-mounted crane, I see them in court. :C Kayteg1 wrote:
Sure, and watch the attorney laugh at you.- BradWExplorer IIHow long is your stinger and how much do you tow?
You can make the stories all you want, but from what I have seen how my 3" receiver and stinger works, I think if you could hire Hulk for the test, he could lift Superduty horizontally holding it by the stinger. - ticki2Explorer
You mean that is not strong enough?
44,065 PostsLatest Activity: Apr 14, 2026
