bigfootgrey
Mar 28, 2019Explorer
Torklift Cannon
(Mod Edit: Link to original article to give the author - Mello Mike - credit)
Article
Looks like a problem solver for newer Fords.
Bob
Article
Bob
Bedlam wrote:
Torklift's ratings are based on using the Ford OEM receiver. It may be a limitation of the receiver with that much leverage........
SidecarFlip wrote:
That, my friend, is a fugly statue.....:E
Kayteg1 wrote:BradW wrote:Kayteg1 wrote:
I build that almost 2 years ago.
Cost of 48" of 3" tubing about $40, including cutting.
That was my plan, but after taking a good close look at the factory receiver hitch, I wasn't confident that it was robust enough for 7,000 lbs on a 4' extension. 7,000 lbs on 2' or 3,500 lbs on 4' seemed OK. It cost a lot more to go with the 30k lb Torklift receiver, but I'm glad I did.
bradw
I did some calculations and assuming older TL stinger was 2.5" tubing with 1/4" walls combined with 2" solid bar, the 3" tubing with 1/4" wall comes well stronger.
In construction it it cross section height what give it main strength.
Than my boat is less than 3000 lb with minimal tongue weight.
I am not worry.
Besides... I tested my receiver/stinger pretty goodClick For Full-Size Image.
bradw
I am not worry.
bradw
