Photomike
May 02, 2015Explorer III
Torklift Glowsteps - Finally
I have been wanting to replace my steps for a long time, I had decided a year or two ago that I would go with some Glowsteps but like most things around here nobody had them or even knew what they were. Then I was going to order a year ago but the "you buy it, it is yours" policy of special orders had me nervous so I waited. This past April I once again started looking and nothing. Then today I called a newer RV dealer and asked a guy in parts (who is not a parts guy) if they had any. He was REALLY confused, asked me to hold and after a VERY long time came back and was blown away as he found a set of steps. Now according to Torklift I needed a 4 step set, this was a 5 so I thought that I would go and look at them anyways. Took the truck and drove in a sure enough they were the steps I wanted, but with an extra step. I asked him what they wanted and when he told me that they were $80 less than the 4 step (higher exchange rate today) so I took them and removed the extra step to make them the right size.
Was planning on mounting them to a angled bracket that I had made a while ago but found that the bolts would not work. So took the bracket off and secured to the camper the way the other steps were when I bought it and the way that I had the bracket attached.
Torklift does not recommend putting on a NL without a bumper but as they are attached the same way that the other steps were for years I cannot see an issue. Will keep an eye out to make sure that they are okay.
Sure is a lot different. I had been told that they were a lot nicer but that does not even come close to how nice they are. 99% straight and a lot stronger than the last set.
