Bedlam
Nov 28, 2017Moderator
They engage the upper overload spring sooner than the stock pads (kind of like setting preload on a coil spring). You now get less sag before the the upper spring engages. When unloaded, you should have a gap to keep the ride comfortable. It will slap the the Stable Load on rough roads at speed when you travel unloaded, so that is the biggest downside to this setup.
