towpro
Jun 06, 2016Explorer
I have the Torklift tie downs on my 2015 crew cab long wheel base dually Ram Without this adapter.
what the adapter does is relocate the rear tie down point on the camper because the fast guns might hit the fenders. The rear torqlift mounts have 2 pin holes where you can move them out further. I use them extended to outer hole. I think inner holes will clear, but what if camper moves a little?.
I did wrap my fast guns with pipe insulation because I have hit the fender when I remove them.
for what its worth, I bought mine from a large high volume dealer online. he said he has not sold a relocation kit since the early 200X dodges.
note: in the middle of 2015 the dodge frame changed just a little. the front mounts I first received would not work on the front passenger side. There was a tab on frame that moved like 1/8" and mount would not line up, as well as the bolt hole was smaller and bolt would not fit through the hole when hooked to "fishing wire" used to pull the bolt through the frame (I dropped bolt and washer inside frame as it pulled off fishing wire, but I got it out with magnet). Torqlift sent me a new mount that clamped on the front RS of frame.
I think one way you can tell if you have this new frame change is the bed will have holes in rear bed on sides, inside, just ahead of tailgate, where they mount the inside bed lights on the 2016's.
44,066 PostsLatest Activity: Mar 14, 2015
