bobbolotune's avatar
bobbolotune
Torklift Tiedowns Original Steel or Talon Aluminum
I am trying to decide between the Torklift original steel vs the Talon aluminum tiedowns.
Truck Camper Magazine interviewed Torklift about the Talons when they were first introduced and the discussion is quite detailed:
www.truckcampermagazine.com/news/tcm-exclusive-torklift-international-talon-camper-tie-downs
I have also read the Torklift website, did google searches, and searched this forum.
My conclusion is that the summary is this. Talons are 30% to 50% lighter but cost around 30% more. Torklift tested the Talons to be as strong as steel (although how can testing really know how they will hold up after 10 years). And the big one, since the Talons are aluminum they won't rust.
In my case, specifically it is $500 for steel vs $680 for Talons. But the Talons include the finishing kit (the caps for the pieces that remain on the truck when the camper isn't loaded) which is worth $20. So really it is $500 for steel vs $660 for Talons.
Are Talons worth the $160 more?
Someone said with steel you should paint them once a year. Someone said to put car wax on the steel to keep them from rusting. So possibly some maintenance for steel. I have plenty of truck capacity so weight isn't a problem, but less weight never hurts.
From the web searches I didn't find a single bad word about Talons. But then there isn't much you can say about tiedowns. Either Torklift tiedown will hold the camper, especially for newer tiedowns which is the case here that Talons have only been out a few years.
I guess my main question is to ask if anyone has had any negative experience with the Talons. Does anyone have any reason not to get Talons except for cost?
If not, it is $160 to not worry about rust. Very borderline decision. The thing is that tiedowns are matched to the truck and you probably won't be able to move them to a new truck. So as long as they last as long as the truck that is all that is needed. I assume there are other critical steel parts on the truck which can also rust. On the other hand, 5 or 10 years from now for a tie down to break due to rust could be very bad and very expensive.
I suppose I am leaning towards spending the extra $160. Opinions?
  • I wanted to buy the Talons but they were not yet available for my new model of truck but the steel ones were so I went with steel. One of my wife's co-workers went with the talons and they had to have one replaced as a weld cracked during installation. Torklift service was excellent but they told them to reduce the torque on the bolts to avoid cracking the welds. I live in an area where rust is not an issue so I'm happy I ended up with good old steel!
  • I would save the extra money for something else. Ran the steel on my 04 for 6 years with no problems. Don't see how the Talons could be closer than the steel ones on my new 15 Ram as there is less than 1/2" clearance to the bed.
    You probably won't use the end caps any how since it is just something else to worry about. Have been down some muddy roads without the inserts and never had a problem with dirt getting in them.
    And with your setup, saving 25# at most isn't going to be an issue. Especially with a dually.
  • Take the money and run. I have steel and leave them on the truck whether the camper is on or not. If they rust I will just wire brush and repaint. Steel, iMO, is a superior material for this application since it will bend rather than snap (aluminum) on failure.
  • I'm looking at the Talons myself. My concern is metal fatigue, since aluminum has only a certain number of bends in it before it shears... but aluminum framed bicycles have the same problem, and those are well engineered enough to not have any freak breakages, so I think it would be a decent alternative. Weight doesn't really matter to me compared to corrosion resistance.
  • I've had Talons on my truck for about two years. I've had zero issues with them.
    On my previous truck, I had steel for 8 years. They did rust a little.
  • I have the steel version on my older truck and the aluminum version on my new truck. They both work well. The talons connect closer to the truck so there is a little more effort to get to the cotter pin for removal and installation. If I lived where there was a lot of road salt used in the winter or I did Ocean Beach driving I might go with the Talons
  • I've had my steel Torklift tiedowns since 2004. I haven't done a thing to them. Absolutely nothing. And there's very little rust. The only issue I had was dirt and gravel getting in the front set and having to dig it out once in a while.
    My thought is on steel versus aluminum tiedowns is that the decision is the same as for buying a steel utility trailer versus an aluminum one. And that the constant flexing of an aluminum trailer results in cracks.
    If it was me, I'd take the weight penalty of steel.
