I have both, and have had and pulled both over the years. My take on it is the main advantage for me of the torflex style is the fact it allows the floor of the trailer to built lower to the ground. Important for a cargo trailer I had ( made it easier to step into for loading ). Same for a current horse trailer I have. The lower floor height is nice for loading. I can't say that I have noticed any real difference in the handling between the two types. At least in theory, the idea of the trailer being lower to the ground should result in better handling, but again, for me, from a practical manner there seems to be little to no noticeable difference. It's true that in time, the rubber rods can and generally do settle and harden. Most folks just replace the entire axle at that time. Common repair when folks are restoring old Airstreams.
I had them on my Palomino and loved the way they felt while towing. Mine was only 12 years old when I sold it so I never had an issue and can't speak for longevity past that. If you feel the trailer is too low, you need to remove the axle and place a block (2"x2" tube or solid stock) between the axle bracket and the frame rail...not a huge project for the right person or shop.
Edit: The more I thought about it...I realize that I had the AL-KO version of that type of rubber/torsion axles on mine. The concept is pretty much the same but with 3 pieces of rubber instead of 4.
The rubber torsion suspensions usually ride real good as individual axles. The pluses are that they are independant and the manufacturer can use the steel tube as part of the actual trailer structure so that they are easier to install. The down side is that the rubber usually lasts 20-25 years and sometime after that timeframe, they start riding rough because the rubber is getting hard. The rubber, in most cases, is not easily replacable, so you need to replace the axle. They don't have an equalizer on tandem axle setups like the leaf springs so that each axle may have to take more of a load than what they are rated for.
Example: If the suspension travel is 5" and you are going over a 7" speed hump, your 8,000# trailer will have all 8,000# (minus the tongue weight) on one axle that may only be rated for 4,000#. Some of the rubber torsion manufacturers recommend rating each individual axle at 1.25 times what the load is intended to be. So your 8,000# trailer should actually use two 5,000# axles. Some manufacturers don't recommend them for triple axles because the tremendous side load can pull the torsion arm out of the axle tube.
They are a good axle setup and if I found the "right" trailer with them, I wouldn't turn down the trailer because it has a rubber torsion suspension. I prefer the leaf springs with the equalizer on multiple axle trailers. The nicest is the leaf spring split in the center for an independant suspension. These were made by Dexter and are rarely used because it is more expensive and there needs to be a center member on the trailer frame to attach the center pivot point.
I have them and my 25' travel trailer rides like it is on rails. Once, I left a half filled soda can on the kitchen counter top. I logged about 75 miles and it was still in the same spot. The Torflex axles tend to make a lower riding aspect to a trailer. They are also not as good bearing load over poor surfaces like back roads and logging trails as conventional spring suspension. My Starcraft is 44 yrs old and the rubber portions of the axles are still together and not cracking. I do have shock absorbers, too.
but years ago.. I had a popup camper for motorcycles. using a similar system
when the rubber went bad.. special tools and a very large hydraulic press is needed.. being mine came from Europe... not fixable within a normal budget.
Just a comment on them. I owned the Dexter ez-flex that I got rid off due to the rubber premature failure. I watched the video that was posted and the rubber on the video already was showing signs of cracking. What will happen in a few years of weather on it. Just my 2cents.
