Bedlam
Oct 29, 2014Moderator
stetwood wrote:
I use mine when unhooked when coming up to stops. Slows the vehicle down without excessive use of the brake. One fellow uses it this way and gets 120K on brake pad changes.
You will have to see how much of a fuel impact it has verses just using your brakes. It definitely is not tuned for economy when running in tow/haul mode. We used to have a Mitsubishi with a sport mode on the automatic which would give you better performance. In this mode mileage dropped 10-15% over the standard economy mode.
44,071 PostsLatest Activity: Aug 30, 2026
