LVJJJ wrote:
I have a '94 GMC Suburban K1500 1/2 ton with 350, 3.73 gears, heavy duty towing package (trans cooler, oil cooler, extra sway bars, etc.) Supposed to be able to tow 10,000 lbs. I tow a 22' 4500 lb Tahoe "Lite" (yeah right, maufactureres info says its supposed to be 2900 dry, it's actually 4300). Use an Equal-I-zer hitch so don't even know it's back there. When we towed a 30' double slide Arctic Fox we did it with an '88 454 3/4 ton Suburban.
So, if you buy this trailer, I hope I don't end up on the same hiway with you.
Actually trucks have improved a bit over the last 22 years.
And what is wrong with knowing a trailer is back there? (aside from sway issues that should always be corrected)
