Hi,
The trailer weight limit is 16,100 pounds. That is for a F-350 with only a couple of options, and only 1 driver (154 pounds) then the GCVWR is taken, minus the truck curb weight minus 154 pound driver, and you end up with GCWR of 16,100 pounds. Add to that a driver of say 350 ponuds or co-driver around 135 pounds and you can exceed the factory assumed curb weight of the truck.
So your actual tow limit might be 15,900 pounds if your curb weight is 200 pounds more than the test truck weight at the Ford factory while printing the brochure at Ford.
Still a trailer with a 16,300 pound GVWR probably has a curb weight around 14,XXX while the tanks are dry, and nothing inside. Just as long as you are not adding more than the recommended weight, you will be fine.
And you will have Perm-A-Grin from that new truck pulling power!
Fred.
