transamz9
Feb 18, 2015Explorer
blt2ski wrote:
The issue with the shuttle. Reality us, that HW SUV IIRC as to what it was, may very well could be certified by an engineer to d that day in and out. While some may say hog wash, reality is, moving said shuttle at 1-3 mph day.in and out has a different spec than towing at 60 mph!
Same with the tires on my bobcat 10.5-16.5 tires in an LR d can Cary 4500 lbs. It if you read the teeny tiny fine print, the limit is 3000 lbs if speeds over 25 mph are ran. Same as a typical truck tire in the same size.
Specs can vary based on usage.
Just as for MY use, the said towing specs are a crock of smelly stuff out the rear of a bull!
How often have you had this Bobcat on two wheels?
