Bedlam
Feb 19, 2015Moderator
Here's another example for you: The Ram 3500 DRW pickup with 4.10 gearing can be rated to tow up to 30,000 lbs. The only way to get that same rating in the chassis cab (that is using the same engine and transmission) is to use 4.88 gearing.
Ram knows that guy buying the chassis cab will be working the truck harder than the typical pickup buyer. They had to change the specification rating between the trucks to cover their warranty period.
