JIMNLIN
Feb 19, 2015Explorer III
op wrote:
Now we’ll look at the trailer weight of 16184.
Fifth Wheel -
Potential PW @20% is 3237
PW (3237) + GVW (6616) = Loaded GVW (9853) (Under GVWR: 10000)
PW (3237) + Rear Axle Weight (2581) = Loaded RAW (5818) (Under RAWR: 6000)
You've dropped some figures in your calculations.
Trucks base rear axle weight is 2581 lbs. Now add 250 lbs for the hitch and 170 lbs (50 percent of occupants on the rear axle) = 3001 lbs. Now add the 3237 lb pin weight = 6238 lbs on the rear axle. The truck is over the 6000 RAWR.
At this point air bags/18" 3500 lb rated tires and wheel will have to be added.
Now lets hope the hitch isn't a 22% which a many are. The 22% = a 3560 lb pin weight.
Like we tell folks its best to get some actual scaled front and rear axle weights and use the GVWR or RAWR method. Both are safe.
That way we won't be telling anyone the 2500 Ram Hemi can tow a 16184 lb 5th wheel.
