MFL
May 25, 2022Nomad II
If your specs say you can pull a trailer weighing 13,200, you should already have the proper trans cooler. Towing a high walled RV, I'd suggest staying at 8K loaded to camp wt. That would be around 1K hitch wt, plus all your gear in the truck.
You absolutely need a trailer brake system. Fords IBC is a great option, that you might be able to add.
Jerry
Jerry
44,071 PostsLatest Activity: Aug 16, 2026
