Grit_dog
May 31, 2022Trailblazer
blt2ski wrote:
Grit,
Issue could come about when owners manual like the one in the T250 I drive at work. Under towing it states 11-12k or so towing with the 3.5eco boost. My van has no factory hitch or controller. This can be a good thing if say the hitch is not rated for more than 10k lbs. Or if factory controller only has ability for a 2 axle trailer, you plan to pull a 3 axle.
Having setup a number of trucks to do what I wanted them to do vs n-ga-neers at factory, thinking they know what I'm going to do within their design spec box. Not ordering this extra dollar cost profit stuff is a good thing IMHO. Then again, IF you fit with in the base spec, it's cheaper than doing everything aftermarket.
A majority of the trucks I've bought new since 81 have not had factory hitches.
Marty
Except it's a van...
Although, I have seen a bunch of half ton pickups recently with no hitches...the dumbarse company I work for ordered them that way since they made a rule that we are not allowed to tow with 1/2 tons!
(Probably someone higher up spending too much time on rvnet and drank the kool aid!)
Since the OP split the scene here, let the off topic discussion roll!
44,071 PostsLatest Activity: Aug 16, 2026
