tuctamExplorerApr 03, 2017tow capacityI know you are all probably tired of answering these same type questions but the more I study this the more I am getting confused. We are "playing" with the idea of upgrading to a 32ft, 3 slide T...Show More
DiskDoctrExplorerApr 04, 2017When the OP said "Dealer says 8520 GVWR and 2350 dry weight." I took it to be a MINIMUM 8520 lbs UVW with 2350 lbs of CCC......or 8520 DRY and 12,350 LOADEDIf you can provide a yeah/make/model of the camper, we can look up the weights.Our 2005 Cougar 304BHS has 2 slides:7300 UVW2340 CCC33' 11" LengthSo another 1200 lbs or so for the OP's 3rd slide and different model seems in line, if interpreted like I did.
Related ContentRam 1500 Towing CapacityTowing capacityTowing CapacityTowing Capacity QuestionNewbie Tow Capacity Question
