RCMAN46
Jun 22, 2017Explorer
Cummins12V98 wrote:RCMAN46 wrote:Cummins12V98 wrote:
From what I have been told tow haul will not allow use of 6th with the AISIN trans.
MeAgain what say you???
Your signature shows you have a Ram with the Aisin transmission.
You also have stated several times in other posts how much better the Aisin is than the Allison.
Confused that you do not know how your transmission works.
MeAgain has the 3.42 gears, I have 4.10's. In 6th I am 1,750 rpm's and he is the same in 5th. I am wanting a confirmation from what I "remember" he said about his staying in 5th towing at the upper limits of his trucks ratings while in TH.
Not sure what I have said about the Allison has to do with this???
What did you mean by this statement? "From what I have been told tow haul will not allow use of 6th with the AISIN trans." I do not see where what MeAgain has has anything to do with the question submitted.
As for the Allison has nothing to do with this but you have often indicated you are the expert on the automatics used in the Ram and GM trucks.
I would think you could have answered the question I put in quotes. I am curious what is the correct answer?
Can tow Haul be used with the Aisin in 6th gear?
