Hardcandy
Feb 17, 2014Explorer
Tow haul button
I have a 04.5 duramax 3500 and I'm not sure when to use the tow/haul button on my gear shift also using this will it help my MPG? Thanks.
M GO BLUE wrote:
ON when towing, OFF when not towing
captnjack wrote:
The owner's manual for my 2002 2500 Suburban with 8.1 liter recommends using tow/haul when towing 75% or more of GCWR.
I just finished a trip during which I was under the impression that tow/haul should be on whenever towing, regardless of weight. I tow a Hybrid Roo 233S at a weight I believe is around 5500 lbs loaded (ballpark anyway). At one point I forgot to engage tow/haul mode. I didn't notice for about 20 minutes or so. Maybe more. I didn't notice any change in driving or handling. Engine temp and tranny temp both stayed low. I began to experiment. The shift points were stretched out a little in tow/haul. I noticed that at 55 MPH I'd be at 2300 RPM in tow/haul and 1800 w/o tow/haul. Seems that for me, tow/haul is doing nothing but wasting gas. Although there were no steep hills involved; I guess that could change things a little.
Seems like cruise control is fine until you hit hills. My guess is that 50 MPH up the hill and 60 MPH down the hill works out to same average speed but uses less fuel.
Thoughts anyone?
Tom_Diane wrote:BenK wrote:Who ever told you that? The tow/haul was designed so that you don't have to manage the automatic as much. The way you phrased it is pretty demeaning! That's like saying that automatics "were invented" for people who don't know how to manage a manual transmission. Even with the TOW/HAUL on, you still have to manage the transmission! Let me guess, you jumped right in and knew exactly how it works and how to use it and you came up with this conclusion? The op asked a question and he got some good answers except when you need to feel good about yourself, you throw that language in there. This site is supposed to be for help and ideas, advice etc. Sorry all but it gets old having to read replies to post such as those that are demeaning to others because someone had a question that seems simple to others! To the op, a rule of thumb is that anytime you hook a trailer up or put 2 or 300 lbs or more in the box, push the tow haul on. Changes your shift point, less strain on tranny.
The Tow/Haul button/function was invented for those who do NOT know HOW2 manage
their automatics by manually shifting....to do down a gear or more...to hold a
gear longer, etc
Pretty soon the OEMs will increase the cost/price and complexity to manage folks
who will NOT and/or do NOT understand HOW2 use the Tow/Haul button.
My guess is electrical. Strain gauge and/or when the trailer plug has
a connection. The TV will then automatically switch on the Tow/Haul function for
the Automatic transmission
gear longer, etc
