Tequila
May 30, 2014Explorer
Tow haul mode
I am sure this has been discussed before, but who uses it and how? I have a 1 ton diesel dually and will be towing a 5500 lb (dry) trailer. I am assuming it will lower fuel economy? Am I correct in as...
Skid Row Joe wrote:S'funny, my Owner's Manual says:....
With a trans overhaul or replacement that runs $3,000+ and a brake job running a few hundred - the math is easy on which system to brake with.
Anywhere, in the United States auto transmission downshifting will potentially harm the transmission. My Ford PSD's owners manual specifically states not using it as a braking device. If your method works for you have at it, but it does your trans. no good - whether you realize it or not is the only difference here. That includes Colorado, btw.:W
