Tequila
May 30, 2014Explorer
Tow haul mode
I am sure this has been discussed before, but who uses it and how? I have a 1 ton diesel dually and will be towing a 5500 lb (dry) trailer. I am assuming it will lower fuel economy? Am I correct in as...
rider997 wrote:Skid Row Joe wrote:
Sounds like it's time for CharieD to get tuned in with manufacturer's recommendations? My Ford HD Owners Manual specifically states to not use it for braking. I'll stay with Ford Motor Company's advice, rather than your's chalee! :BCharlie D. wrote:
Time for Skid Row to get tuned in with the new transmissions. They are designed for grade braking. Coming through western New Mexico from Show Low and through Montana and Wyoming I used my T/H to minimize braking and watched by transmission temps. carefully. It never raised temps. more than 10-15 degrees above flat land towing did.
The 2014+ GM 1500 trucks have "grade braking" that's automatically enabled in aggressive mode when tow/haul is enabled.
1/2 ton truck, gas engine, towing 8,000 lbs, and you don't need to touch the brakes on a 6% downgrade.
And the integrated transmission temperature monitor shows that the factory cooling is doing a great job...
The HD trucks are even better than this.
