Jhurk's avatar
Jhurk
Tow Haul Mode
Just had my first trip with 2014 3500 Ram Diesel pulling 2009 34' Cardinal. Pulled great up some long 6-7% grades left in tow haul mode kept it at 55 mph no problem! When going down hill with exhaust break on and in tow haul it slowed down too much. It would gear down to 3rd 40-45 mph 2700 rpm. I disengaged tow haul and manually down shift to 4th much better 50-55 2,000 rpm. What do other folks do?
  • southernsky wrote:
    Redwoodcamper wrote:
    I leave it in tow/haul in my 2011 3500. It does every once in a while downshift a little aggressively, but you can just feather the gas a tiny bit and it won't downshift. Or use the cruise if it is a straight road with no traffic.
    I do the same with mine
    Same here too.
  • IdaD wrote:
    Are you using Auto or Manual for the exhaust brake? Auto should hold whatever speed you set it at.
    Yep. Tow/Haul with automatic exhaust brake holds speed very close.
    KJ
  • I leave it in tow/haul in my 2011 3500. It does every once in a while downshift a little aggressively, but you can just feather the gas a tiny bit and it won't downshift. Or use the cruise if it is a straight road with no traffic.
  • Tow Haul auto for me.
    I set the down hill speed and the tranny holds it there. RPM's go up but that's the way it works.
    Great featured.. never touch the brakes going down a hill unless I want tow haul to reset to the new slower speed.
  • I usually turn TH off on downhills, preferring to select the gear I want. Same on uphills.
  • Are you using Auto or Manual for the exhaust brake? Auto should hold whatever speed you set it at.
  • I engage tow mode, exhaust brake, and cruise control and never touch any peddles on the floor. Mine holds steady within 2-3 mph difference. It shifts down and up on it's own to hold the speed, and is absolutely marvelous with towing the trailer up and down mountains. I think the steepest grade I was on was 5% (Appalachian Mountains in WV). I let it down-shift, and never gave it a second thought, even when I though the RPM's were a bit high.
