ib_leblancExplorerJun 24, 2013Tow haul mode?Pulling 10,000 lb fifth wheel with f350, 6.4 deisel.. do you have to always use tow haul mode even on flat interstates?
GearitisExplorerJun 24, 2013I have been using t/h since its inception. It is recommended to use it whenever you tow. In recent years it actually changes the logic in the TCM and PCM to correspond with the loads and braking. Shift points and rev limiter also are modified.
Related ContentTow/Haul Mode?Tow/Haul ???Hauling waterChevy tow/haul questionTow Haul button location
