ib_leblanc
Jun 24, 2013Explorer
Tow haul mode?
Pulling 10,000 lb fifth wheel with f350, 6.4 deisel.. do you have to always use tow haul mode even on flat interstates?
Jim and Barb wrote:
What I have read the Tow Haul is to lock up the torque convertor in the transmission. Without going to deep in it basically this reduces the fluid resistance that turns the internal parts that make you move. By eliminating this this will greatly reduce the heat in the transmission. This will reduce the problems associated with excessive heat problems and repair bills. With that being said I engage the button when I start the engine when I am towing. I tow with a 2006 Dodge 2500, 5.9 Cummins R 48 transmission with an added after market Aluminum transmission pan designed for cooling.
