ib_leblanc
Jun 24, 2013Explorer
Tow haul mode?
Pulling 10,000 lb fifth wheel with f350, 6.4 deisel.. do you have to always use tow haul mode even on flat interstates?
hdave wrote:Partially right - The 6.7 does have an exhaust brake, and it's controlled automatically through the tow haul mode.
The Ford doesn't have an exhaust brake.It is a program that is built into the TH Mode
LastOfTheBohicans wrote:Fulltimer50 wrote:Cummins12V98 wrote:
Every time I start my truck I hit the TH and EB buttons. Keeps the line pressures up un the trans and keeps the trans from going into too high of a gear and lugging, example 6th at 45. Also allows the EB to work the best so the brakes last longer solo driving and also slows the trailer when towing. Also keeps the turbo/EB working properly.
Where is the EB button?
I have the same truck as you, 2011 F350SRW 6.7PSD.
There is no switch for the exhaust brake. It is always there. To activate, you just need to tap the brake.
I used it going down the Sunwapta Pass on Highway 93 in the National Park. It kept the whole rig at a nice even 80kmh. No stress, no white knuckles, no moving from gas to brake and back again.
RAS43 wrote:john&bet wrote:Allworth wrote:Not with my current truck I won't do that. I connect, put it in "D" and go. I push it occasionally towing or solo.
The company would not pay to install it if they didn't think you should use it!
Trailer connected --- Tow/Haul on!
X2 I use it in our mountainous areas but on flat ground I do what you said-put it in drive and go. Just like with cruise control, I can control the truck better and get better fuel mileage when I control what the truck is doing. JMO
caberto wrote:+1
When I'm towing. I set T/H mode and forget it. It does the job it's supposed to on flat, up and down hills, and haven't had any issues.
