I'd like some advice on purchasing a TT that can be towed with a 2014 Ford Expedition with the toe package. 5.4L V8 310 HP 365 lbs ft torque 3.73 axel ratio. It's rated to toe 9000 lbs. We're conside...
Good thing to do is to do some research on your tow ratings and get your rig weighed as if you are traveling, complete with fuel, family and whatever you plan to carry in your TV.
Plan on adding 1,000lbs, easy. By the time you add plates, bedding, toilet paper and whatever makes you comfortable you will have come close to 1,000 pounds and even over.
