My 1-ton dually 4WD diesel pickup needs to be towed to the dealership... The tow truck driver showed up with a regular (not flat bed) two truck and plans on towing it with the front hooked up... ...
Bryan don't you mean that the transfer case needs to be in neutral to tow with the transmission in park? Repoed a few 4X4 trucks in the day by simply hooking up and shifting the t-case into neutral. Takes the transmission out of the equation.
