jerem0621
Apr 15, 2014Explorer II
I agree with APT! Go scale the rig! Make sure your tires on the truck and the TT are aired up to 100% capacity and then make sure your WD hitch is set up correctly. If you use a friction sway bar, add a second one to the other side of the a frame.
You may find that your wiggle goes away after these few things are addressed.
Buy a HD truck when you need one. It's too easy to spend someone else's cash.
Thanks!
Jeremiah
Thanks!
Jeremiah
44,070 PostsLatest Activity: Aug 07, 2026
