JCK
Dec 05, 2020Explorer
I’ve seen as high as 18 amps going to trailer batteries on start up of truck. And hour later or so still seeing 6 amps. Even if voltage is 13.2 to 13.4 amps is what gets the job done. Sure it won’t fully charge but on a 4 to 6 hour run I’m usually close to full charge.
I’m using AGM batteries with low charging resistance. The charge line on my truck carries a 40 amp fuse so manufacturer has to size charge wire to carry load.
