I had a 2013 F150 with Eco pulling a 6800 pound trailer for several years. Power will not be an issue for you. I weighed my combo set up for camping, and found I was 500 pounds over rear axle weight. You shouldn't have that issue as your trailer weight is less, unless you really load up the truck bed. The 2 issues I did have were the unsettled feeling when a big truck went by (you can overcome that if you anticipate the truck coming), and during my semi-annual crawl under the truck to inspect the hitch, I found the receiver was splitting out- it was already about half way back. I got it welded and reinforced, but as I was ready to get another truck (for other reasons), I went with an F250 this time.
