“”You, DON'T account for heat. The engineers have already done that. You always set them cold. If they are at correct pressure, the heat buildup is normal. Now, if one gets low that will create excess heat that can raise the pressure to the point of a blowout.
Mark””
I do not agree. The manufacturer list the MAX pressure on their side wall. Granted they usually say cold, but anyone who thinks they engineered all road temperature conditions, I have a bridge across the Grand Canyon I’ll sell you. Set to 80 PSI then drive through Yuma on a 120 degree day, bad idea. I’ve aired to 80 PSI then hit the road and observed 86 PSI, which I’m good with, but where I live the temperature (and more importantly) the asphalt gets so hot it starts to melt. You can’t just air to max (cold) and take off, because you need to compensate for the time of year and where you are heading.
