Ejraste
Jul 06, 2020Explorer
Tow weight
Im new to the rv trailer world. I am currently in the market for my 1st travel trailer. The idea is to eventually find a full time/seasonal campground that has full amenities. I have small children an...
nickthehunter wrote:GrandpaKip wrote:They do test the frontal area, from 12 sft through 60 sft - Read the Standard so you know the facts instead of relying on hearsay.Ejraste wrote:afidel wrote:
Correct, J2807 is based on full fluids, a 150 pound driver, and 10% tongue weight using a flat deck trailer with heavy weights adjusted to give the desired tongue weight. It's not at all representative of what real users tow or how most of us use our vehicles. I've talked to several people in the industry about a more realistic tow test using an average family of 4 with 2 teenagers and a few hundred in the bed and a max frontal area but because it would result on smaller numbers everyone has said it would never fly as marketing would kill it.
Honestly I think the test they do, especially the 11 mile Davis dam test is much harder and more demanding than the normal person would pull. Over 3000 feet of elevation over a short 11 mile stretch going a minimum of 40 mph. So for example, if the 2020 Silverado pulled the 9500 lbs through that stretch of elevation and demand without any issues, I would say that pulling 7000 to 7500 lbs would be no issue. And they actually use a 150 lb passenger as well on their runs.
But they are not pulling a wall through the air. As has been said, for RVs, tow weight is basically useless as you will not hit that number before running out of payload.
Tow weight is fine if you are pulling a flatbed full of lumber. Build a front facing wall from that lumber and the result is totally different.
