I believe that is what I have in my 2005 Liberty. The transfer case should offer 2WD, 4WD (part-time aka 4-Hi), 4WD (full-time aka AWD), neutral, and 4WD (part time) Lo.
You must tow either 4 down or on a trailer. Dolly is absolutely not useable). To tow, put transfer case in neutral and tranny in park. Do not tow with tranny in neutral or in gear, as that will damage the transmission.
To change transfer case setting, the Jeep should be rolling, but not under load. A couple miles per hour is all you need there.
