Foy's avatar
Foy
Towed weight tables?
After a mere 50 year absence from the ranks of pop-up camper (folding/tent)users, I'm starting to test the waters for a used PUP. Key in my search is towed weight. From just a cursory review of some used unit listings and an equally cursory review of manufacturer's data, the towed weight numbers are all over the place.
My goal is to find a unit down in the 2,000-2,200 lb range in order to keep it well below "trailer brakes" limits and well below the maximum towed weight rating of my 2010 Equinox (3.0 liter V6) and my Mazda B3000 3.0 V6. Much of my towing will actually be with my venerable Superduty diesel, but the unit must be reasonably tow-able behind the car or the little truck, for a variety of reasons.
The question: Are there dry weight and/or wet weight tables listing PUPs from various manufacturers over the years? My target price range will likely have me in the early to mid- 2000s model years, perhaps as "new" as 2007-2009 or so. Without tables, I suppose I can just continuously refer to published manufacturers' specs for each make and model over the years as I see interesting units on the market, and it appears that such make/model specific tables are readily available.
Thanks for any tips and advice.
Foy
  • Better look at your tow rating for the Equinox. I'm bettin its around 2000lbs, and no more than 3500lbs with the tow package.
    At any rate. Look at the pup's dry weight, and the weight carrying capacity. Many can only carry 600 to 1000lb over the dry weight.
