^ But it does have a gear ratio or 2 that are close to 1:1, so what’s your point?
Many newer auto transmissions don’t have an exact 1:1 ratio gear any longer. And many do.
What is worth noting, is there is nothing magical that happens at 1:1, it’s just another step in the gear ratios from under-driven to over-driven.
And “OD off” is a thing of the past that was used on 4 and 5 speed transmissions to limit upper gear ratios. No different than manually shifting it via the gear shift or range buttons to limit the upper gear that the trans will shift into.
I’ve not seen it on any vehicles I’ve driven in recent years that have 6 or 8 speed transmissions.
