time2roll
Mar 25, 2017Nomad
mobeewan wrote:My 4WD shift-on-the-fly is good to 45 or 55 mph but not speed limited once shifted.
4WD high is usually limited to 40 to 45 max. Any faster can cause damage. Read your manual. It should tell you.
4WD low is going to rev up the engine a lot sooner.
Low range you will run to the rev limiter fairly quick.
44,056 PostsLatest Activity: May 04, 2014
