mcadaman's avatar
mcadaman
Towing 20' camper with Jeep Liberty
New to RVing and just wondering if anyone pulls with a Liberty. We're picking up a Rockwood Geo Pro G15tb in Ohio. We live in Texas. Dry weight on trailer is 2445 lbs. I could use some tips. Thanks!
  • Forget dry weight, it is meaningless for our purposes. By the time you add propane, water, food, clothing etc etc it will be north of 3,000 lb. What is the towing capacity of your vehicle from the door sticker?
  • At max weight each of those two tires on this single axle TT will carry about 1750 pounds. What is the max load on the factory supplied tires? My TT weighs 5200 pounds loaded and wet...about 1250 on each tire..hint hint.
  • Dry weight doesn’t mean anything. 3500 minimum loaded and wet. What is the Liberty”s payload and max trailer weight? “Pulling?” My daughter’s Volt will “pull” it.
