shirleyj62's avatar
shirleyj62
Towing 6-7000# Trailer with Toyota Tundra
I am posting this for my son. He is looking at purchasing a 2017 Toyota Tundra to pull his trailer.
We are looking for feedback from other Toyota owners who pull a >5000# trailer.
Have you modified the suspension in some way? (I.e., air bags, additional springs, etc)
What's the longest drive you've done pulling this trailer? Most trucks can pull a mid-sized trailer a short distance. How did it handle mountains? How did it handle the passing semi's on the interstates? Do you feel comfortable pulling your trailer?
Any additional comments, pros, cons, etc., would be welcome.
We also don't want to get into a Toyota vs Chevy vs Dodge vs Ford debate. We are purely interested in your opinion about the towing capabilities of the Toyota Tundra.
Thank you.
  • Does the truck come with tow mirrors? If not, probably not designed for towing anyway.
    Really? Well I guess my Ram 2500 is not meant to tow either. Yup, tow package but no tow mirrors.
  • The 5.7 is rated to tow 1100 lbs. Gas mileage is poor unloaded but fair while towing. You will have no problem with that trailer.
  • The Tundra will pull that weight trailer without issue. Plenty of power and good tow gearing. No problems passing, holding interstate speeds or pulling grades. Fuel economy isn't great but Toyota finally added a larger gas tank for the '16 model year.
    Where you need to watch though is the payload. What model and trim is he looking at? A loaded crewmax is around 1200lbs payload, a double cab fairs a bit better at around 1400lbs. The tongue weight will eat up a fair bit of that. So things really depend on how much additional weight he plans to carry in the truck (passengers, stuff in bed)
    For comparison I towed the tt in my sig (7600lbs loaded) with my '07 crewmax limited for 2 years. Some long 3k trips in some pretty good grades. The Tundra pulled it without breaking a sweat and actually pulled better than our current Ram 2500, but with the family on board we were always around 400lbs over payload but more importantly under the axle ratings. We did upgrade to E rated tires and added airbags for comfort, not necessity.
    The Tundra is a great truck, wish we still had ours. If the numbers work I highly recommend it.
  • Can you look at the placard on the TUndra and give use the
    GVWR
    curb weight ETC
