Mickeyfan0805
Feb 25, 2014Explorer
jlfought wrote:
Am I following? The 8600 is way different then the 2,000-2100 range Mickeyfan had thought though. We were looking on the sticker in the door that tells us the Tire and Loading Information for "The Combined Weight and Cargo Should Never Exceed: #" but it is not listed. We also tried to look this up for the 2003 Burb 2500 and couldn't find it anywhere. Is this the # that you were referring to?
Yes - you're getting it. The 2,000-2,100 number I gave you was the payload, which is what is left after taking the curb weight of the vehicle away from the GVWR of 8,600 you listed. The only way to know EXACTLY what your payload is would be to take the truck to the scales and weight it, then subtract from the 8,600. The result will be somewhere in that 2k range.
As for the hitch, you are correct. There were known hitch issues in that generation of Suburbans, so many people suggest swapping them out anyway. What the hitch can handle is solely a question of the hitch and has no impact on the capacities of the vehicle. You can get quality hitches that you can install yourself that would handle any load the truck could handle (Our hitch has a 1,500/15,000 rating).
44,056 PostsLatest Activity: May 04, 2014
